Cleaning Stainless Steel
Whats the common practice out there for use of carbon steel wool to clean exposed stainless surfaces?
(note: this is for clarification of a discussion on a atomotive forums. I have been challenged by someone who says he has a mat.sci degree and always polishes stainless using carbon steel wool. My response is that there is too much chance of embedment of Fe into the surface of the SS causing rust spots.)
Nick
I love materials science!
RE: Cleaning Stainless Steel
I've always used clean Scotch-brite or other clean abrasive to polish stainless.
You could start with steel wool to remove the debris, then follow up with a very fine silicon carbide wet paper to remove any small bits of carbon steel left behind on the surface of the stainless. Finish off with a nice final pickling and passivation treatment and you should be good to go.
Of course, you might skip the last stem due to environmental concerns if you are doing this work in your garage on your deLorean.
You will end up with rust spots from the steel wool.
If you can't pickle or passivate then use a ScotchBrite type of product and lots of good clean water.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
Michael McGuire
Rust never sleeps
