diesel generators
diesel generators
My company is about to buy some second-hand diesel power generators, rated 3.2 MW at 13.8 kV, with about 24000 hours use.
Are there any standard test protocols for this type of unit?
Matt
Matt
RE: diesel generators
The basic check points will be the insulation resistance of the generator and, if possible, the exhaust temperature of each cilynder under load.
The overriding consideration is the fuel economy. These sets will each burn about two million gallons of fuel a year. The purchase price of older less efficient sets should and usually does reflect the increased operating cost. I have seen a purchaser go with a slightly less efficient set when it was a make that their crews were familiar with and were trained in overhaul procedures.
I hope thios is helpful even though it doesn't exactly answer your question.
respectfully
Inspection tests to determine whether you should actually buy them or performance tests to carry out once they are installed in your facility?
If it's the former I would urge you to get a full inspection carried out by an independent expert before you even consider buying them.
If it's the latter you could use the protocols set out in ISO 3046 and 8528 (I recall Waross stating the commonly used US standards in another thread if you're across there).
The issue here though is your warranty/guarantees -who is going to give you one? The OEM? What will you do if the engines fail the tests after you have bought them?
Matt
