Hole Wizard on an angled or curved surface?
Is there a way to use Hole Wizard to counterbore into an angled or curved surface, like into the surface of a turned part, or as a spot face on a casting? The way I do it now is to create a plane at the bottom of the counterbore and create a sketch for the thru hole and one for the counterbore. It would be much simpler if I could use the Hole Wizard instead but it doesn't seem to work on a plane.
Tom
RE: Hole Wizard on an angled or curved surface?
How do I create an angled hole using the Hole Wizard   FAQ559-1156
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
