Camera View Quality
Camera View Quality
I have defined a camera view which has really poor performance in that the resulting image looks like the image quality when rotating a large assembly.
ie, cylinders have become rectangular blocks. Smaller components are blobs.
Large assembly mode is turned off and all other perfomance/image quality sliders are maxed out. Note that when not in camera view all the components are displayed absolutely fine.
Is it a system limitation?
Quadro FX go 700
1 gig ram
1.6 Pentium M processor
SW06, SP3 (photoworks not installed)
Anyone else have this issue?
Quadro FX go 700
1 gig ram
RE: Camera View Quality
I'm running Solidworks on a low spec machine, which we upgraded.
Before the up-grade the slider on the shaded & draft quality moved showing a rounder circle in the picture box, but didn't make a difference to the actual model (especially cylinders).
Sounds like an hardware problem as the spec sound O.K.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
