High Pitch on Air Compressor
We have a 10 HP Ingersoll Rand 2 stage air compressor at work which is only 1 month old.  We ran the air lines and built a enclosure around the compressor to quiet the compressor noise down.  The problem is that at sometimes a high pitch like a tea kettle sound comes from around the regulator.  We replaced the regulator and it does the same thing.  Some thoughts like maybe the checkvalve may be having problems.  We have 1 inch piping coming out of the compressor and it goes down to 3/4 inch to the regulator and out and is 3/4 inch piping down to 1/2 inch line.  I don't know if I am in the right forum but I would appreciate any suggestions possble from anyone.  Thanks from Cedar Rapids, Ia.
RE: High Pitch on Air Compressor
Did you replace the regulator with the same model or a different make/model?
Regulator rated for the CFM?
Why are you reducing the air line down to 3/4".  You are supposed to keep the air velocity below a certain speed; 30m/s.(I think) You may be exceeding that by a lot.  Could make some noise.
Others may have some ideas too.
Got a link to your specific compressor on the IR site?
Keith Cress
Are you using a storage tank? If you are running the regulator on the discharge of the compressor without a pressure tank the regulator may be having trouble coping with the pressure pulsations coming from the compressor.
respectfully
Take a look at downloader valve #2.  Normally the factory puts a rubber gasketed fitting around the coupling, which sometimes get loose (or never was tight), and it might be acting like a reed in a saxophone or clarinet, causing the high pitch sound.
Sometimes I have seen (when the IR folks screw up) them put a compression fitting instead, which often won't seal.
BK
I had a noisy compressor once.  I loosened the bolts that hold the air intake.  It only took about a quarter turn and the noise went away.  You never know what is going to resonate...
It has been running fine ever since.
