Backup S5 CPU
Backup S5 CPU
Does anybody know how to copy the complete PLC program&data in a S5 CPU in order to have a backup project in the PG to be used as a master to write new eproms?
I have 3 S5 plcs (S5-95, S5-100 CPU 103, S5-115 CPU 944). I would like to create relevant projects in the PG.
Thanks a lot!
Thanks a lot!
RE: Backup S5 CPU
--Off all the things i've lost , i miss my mind the most--
RE: Backup S5 CPU
One point though, if you find the documented program and its not quite up to date with the PLC, DO NOT UPLOAD from the PLC over the documented program. Two reasons:
1. All DB's will lose their format, you'll get every word displayed as KH losing all the formats put in when initially programmed.
2. Any added or deleted segments will cause the OB's, PB's and FB's segments commenst to go out of sync.
