DOM Tubing % Work Hardening?
Is there a common method for estimating the % work hardening and/or yield strength / TS improvement for a given material for DOM versus as welded thin wall ERW tubing?
Are there any good references for this type of analysis?
RE: DOM Tubing % Work Hardening?
Also remember that steels don't work harden much. It takes a lot of cold work to raise the strength much.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
