problem with scenes - blacked out box on draw view
Catia V5R16 SP03
I have created a scene, and am attempting to make a draw view, using dynamic shading with edges.  When I put the view on the draw sheet, it constantly comes out with a large black "box" over approximately 1/3 of the part.
What could be causing this?  Coincidentally, the place where the box appears on the view, is always where the view properties dialog appears, when I turn on the colors and shading.  I can't generate the view by changing the drafting options before creation, because the view must be scaled down. (or else I get a memory error - and no view)
CAD design engineering services -  Catia V4, Catia V5, and CAD Translation.  Catia V5 resources - CATBlog.
RE: problem with scenes - blacked out box on draw view
Solid7, I won't have a chance to try it right now on one of my machines with SP3, but SP4 is out, I have it loaded on mine. This may correct the graphical issue.
I didn't get a chance to get SP04, as I currently have not paid my maintenance. (it ran out last month)
I need to do that now, I guess...
I just got SP04, and can confirm - the problem still exists.
I will try an example tomorrow, leaving for the day
Here is some additional information:
This is a 1/4 scale view.  When I attempt to shade the view as full size, I get the following message:
"Memory allocation failed."
Seems like this is my best clue yet.
