Backfill and filter for clay subsurface drain?
I am building a subsurface drain (french drain)in a high clay soil. I am planning on backfilling the trench with sand to filter the clay and using a drain sleeve filter on the perforated drainage pipe. What sand and AOS filter should I use?
I have seen C33 sand is recommended. If I use a ASTM D6707 filter with an AOS of 0.6mm, then almost half of the sand will be smaller than the filter. Will the filter clog?
RE: Backfill and filter for clay subsurface drain?
