licensing through VPN tunnel
Hi all,
Does anyone know whether it is possible to get a network license granted through a VPN tunnel?
Thanks.
Thanks.
RE: licensing through VPN tunnel
Derek
I could start CATAI remotely today morning.
However, when I want to open a CATPart or Product file, which is on the local disk, I get "Wrong application level", "Invalid data structure" errors.
These files have been created with the same version of CATIA.
Apparently, I can create parts but I can't open existing files.
Any idea how to fix this or what's wrong is appreciated.
Derek
We're running V5R15. I don't know the SP level. How can I find it out?
There're other things which aren't right. I started CATIA at home and apart from the issue mantioned above, it seems normal. However, when I look at CATIA, running concurrently in my office, via remote desktop, the screen is empty. The window title shows that a drawing is loaded but the screen is empty.
Laszlo
Laszlo
Derek
Is it possible that my DSL line is fleaky and since CATIA checks the license periodically, at some point it didn't get permission from the server?
Laszlo
DEMO mode has to be unchecked in Option/Licensing.
Great, it works!!!
Thanks again for your help.
Laszlo
You might try to set this directory AVAILABLE OFF LINE.
Note: Do not EVER make CATIA documents available off line - you will permanently corrupt them.
Maybe it is not shown because I've never downloaded a service pack.
Where do you download the service packs from?
Derek
https://w
This is the "official" place to get your service packs and hot fixes.
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
