Combining Parts of an Assy?
If I have an assembly containing 2 bodies that mate to each other, is it possible to combine them so I can save the assembly without external references?  I took a plastic injection molded part created a split and subsequent assy of the 2 halves.  I would now like to save the assy without the external references of the individual files.  Hope my intention is clear....
Bloodclot
I come from a small town where the population NEVER changed.  Everytime someone got pregnant, someone left town.
RE: Combining Parts of an Assy?
you could try making a joined part, saving out as a part... or with SW05 you can make a part without external references... but if you want ot save an assembly without external references you will probably have to export it out as a parasolid and bring it back into as a dumb assembly model.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Join works well, though it's kind of a convoluted process.  Follow the help directions exactly.
If I understand right, the simplist would be to do a 'Save As'.  Just select 'Save As Type' Part.  This'll leave you with a dumbsolid made of 2 seperate solid bodies.
ongybill
It has worked for me using the Join function.  However, FYI, anytime you save an assembly as a part file it changes the solid bodies to surfaces only.  Not a problem unless you will be doing a section view.
-Bloodclot-
There is a check box to save the Assy as a Part with "All Components", that should solve your "surfaces only" problem.
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
or external components, either one will get you solid multi-bodies... better then surfaces
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
