Just Wondering if anyone has....
Has anyone constrained a part and the lines turn black?
RE: Just Wondering if anyone has....
I have had a problem with this in the past. Try shading the product without edges. This will be the very top selection. If the lines don't return to the nornal color then I can't help you. If it does correct the problem, then it seems to be a graphic problem. The problem only shows up once in a while for me. You may want to try to reset the graphic settings within the product or parts.
Hope this Helps.
Chewy3000
Derek
Derek
