Leading zero's
Leading zero's
Leading zero's
I need to pu serial numbers into a spread sheet complete with the leading zero's. I need 00001234 not 1234.
I've done this in the past but can not remember how.
Can any one help please?
John
ps it's excel 97.
RE: Leading zero's
Format->Cells and choose "Custom".  Type as many zeros as you want to have places.
RE: Leading zero's
Try putting a single quote in front of the s/n. Then it will treat it as text and display exactly what you typed.
RE: Leading zero's
Format->Cells and choose "Text". All values, including numbers with or without leading zeroes, are treated as literal text
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
RE: Leading zero's
thanks handleman that worked.
electricpete that worked but caused a problem later in the process, but thanks for the suggestion
John
RE: Leading zero's
On Column or Row or Cell : Right click ->Format Cells ->Number -> Custom -> On type ENTER # of LEADING ZEROS YOU WANT....gOOD  LUCK!
RE: Leading zero's
Format as 00000000
Hope this helps.
maybe only a drafter
but the best user at this company!
