Anchor Bolts for Aluminum
I've got a project where Aluminum columns (and base plates) are being anchored to a concrete pier/footing. The contractor used your everyday common steel threaded anchor rods. In less than two weeks they are completely rusted over. The contract documents called for hot-dipped galvanized anchor bolts. (before judging, we did not provide the design or specifications, simply consulting on a separate portion of the larger project)
I'm thinking of having the contractor cut off and drill-in epoxy grout anchors.
Will the galvanized anchor bolts react to the aluminum? Should I use aluminum anchor bolts? If alum, what affect would the anchors have in steel reinforced concrete?
Thank you,
MLM
Thank you,
MLM
RE: Anchor Bolts for Aluminum
As an extra precaution the contact areas could be painted with insulating paint.
http://www.welding-advisers.com/
MLM
Aluminum embedded in and in direct contact with concrete is not acceptable. A chemical reaction occurs and the concrete literally self destructs from the expansion (product of the reaction, just like rust on carbon steel that is allowed to corrode in concrete). I don't know about epoxy grouted aluminum in concrete but I've seen slabs with aluminum cast into it break themselves apart.
MLM
Also, thanks for the input.
being inserted in aluminum bodies. Usual anodizing or conversion coating are not protective enough at the contact place.
