Welding spark sticks on Cu conducting clamp
Our Pickling line uses flash butt welding machine for joining steel sheets. During welding of the steel sheets, sparks tends to stick on the clamp, which is a Cu based material, adjacent to the weld area, as this Cu clamp is to conduct electricity for welding process. Does applying some ceramic coating on the Cu clamp helps? Or what can be done such that the welding spark doesnt stick to the clamp?
RE: Welding spark sticks on Cu conducting clamp
You might try to use any of the anti-spatter products offered on the market to avoid sticking.
http://www.welding-advisers.com/
h
An alternative to the anti-spatter approach is to use an Aluminum metal spray (Al metalize) on the affected side, not the contact side, of the contact bar.
