pvc vs rcp
pvc vs rcp
What are the pros and cons regarding the use of black corrugated culverts vs concrete pipe for storm drainage?
Thank you, rrw
Thank you, rrw
RE: pvc vs rcp
I think it will be informative, then perhaps you'll have more specific questions.
RE: pvc vs rcp
In a nutshell:
HDPE
Pro: usually less expensive. Because it is lighter, it is easier to install in most situations.(wants to float in a wet installation)
Con: much less forgiving than RCP when installed improperly. poor practices in bedding and backfill leads to dramatic failures. (poor construction practices can still lead to RCP problems esp. joint failure)
RCP
Pro: contractors are used to working with it...more familiar. more forgiving than HDPE for bad installation practices. Depending on class of pipe, can be used in shallower cover situations.
Con: typically more expensive material and installation.
RE: pvc vs rcp
