top strut bearing
top strut bearing
I am developing a modified front suspension that requires a custom top strut bearing. Can anyone recommend a company that can work with me on developing this component? My annual requirement will be several hundred to 2000 units.
Thank you,
Thank you,
RE: top strut bearing
Are you sure it doesn't exist already?
Still don't know what you are up to, but using a coil spring on a strut is extremely common. The upper spring seat us usually affixed to the strut shaft so it all rotates together. Above that is a flexibly mounted bearing.
