Exporting line color
Back when I was using SE12, I frequently exported .DFT files as .DWG files with specific colors assigned to certain lines.
These files are being used on a laser cutter where the laser will react to the different colors with different power settings.  Being able to export the colors accurately is key.
Now using SE15, when I export a file as .DWG all the line colors revert to black.  I have explored the exporting options, but there are no references to exporting line color settings.
Is there something I am missing here?
Thanks in advance!
-Tim
