Step-up dc-dc converter
I need some help in creating a dc-dc converter with the following specifications:
Input voltage: 1.2V
Output voltage: 9.6V
Output current: 3.5A
The input source will be one rechargable NiMH D-cell with a capacity of 7000mAh.
I know this is a lot to ask from a single NiMH cell, but it can easily handle 30A.
RE: Step-up dc-dc converter
I would like to suggest to consider an alternative approach:
For a step-up ratio from 1.2 V to 9.6 V a simple boost converter would require a large inductor. A converter using a transformer with mid-tap on the primary would a better approach. This would still be a challange to an experienced designer. What are the disadvantages of connecting more smaller cells in series and using a simple boost converter?
At the moment I use 8 cells connected in series.
The reason why I would like to use one larger cell instead is simply that it's much cheaper. I can get a single 7000mAh cell for about 1/5 the price of an accu pack with 8 cells.
