Catia V5R15 to Catia V5R11 Translation
I have a product file built in Catia V5R15. How can I save this file as a Catia V5R11 file?
RE: Catia V5R15 to Catia V5R11 Translation
Can I you Tools/ Utility/ DownwardCompatibility to translate the file as a R11 data?
Good luck.
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
Please let me know the steps that I should follow to translate the file from R15 to R11?
Thank you for your help.
Tools - Utility - Downward Compatibility
It will only translate the PartBody, which will end up as a dumb solid.
Derek
The steps for using the Downward Compatible Utility are in the online documentation. You should look it up first, and ask specific questions if you still need help after that.
