Convolved vs Convoluted
I often see the word "convoluted" where I would normally use "convolved" (i.e. the product of convolution). Is this an American difference (e.g. like burgle vs burglarize), or just plain wrong?
RE: Convolved vs Convoluted
to convolve
to convolute
As far as I know, these two verbs are synonomous.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
con•vo•lut•ed
adj.
1. Having numerous overlapping coils or folds: a convoluted seashell.
2. Intricate; complicated: convoluted legal language; convoluted reasoning.
con•volve
v. con•volved, con•volv•ing, con•volves
v. tr.
To roll together; coil up.
v. intr.
To form convolutions
What do you get when you compare the definitions of the two verbs:
convolve -
convolute -
Similarily, what are the defintions of the two infected adjectves:
convoluted -
convolved -
I also find it interesting that the definition of the instransitive verb 'to convolve' is 'to form convolutions', which is the noun inflection of 'to convolute'.
To me, 'orientate' falls in the same category as 'irregardless'.
Good Luck
In the Macquarie (Australian) dictionary, "orientate" is actually given priority over "orient".
According to Fowler's "Modern English Usage":
"There is no meaningful criterion for choosing between them, except that "orient" is shorter and therefore less cumbersome in some contexts."
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
