Bolting Temperature Ratings
I'm having problems in finding the recommended temperature ratings for the following bolts; note that I've downloaded the applicable ASTM documents, but found only vague information:
N Drawing ASTM Material Head Marking
N14 A354 Gr BD Alloy Steel 6 Radial Lines
N14A A193 Gr B8M Cl2 AISI 316 B8M
Also, is there any standard definition for the range of temperature ratings?
RE: Bolting Temperature Ratings
ASTM A 193 B8M Class 2, the maximum temperature for use in flanged joints is 750 deg F.
ASTM A 354 Grade BD, the maximum temperature is 650 deg F.
