error: "no results selected for display or deformation"
I'm running I-Deas11 on winXP. After creating boundary conditions, fem1, meshing, solution set. I solve the system, calculation goes well (except I can't see the graph with the amount of equations solved...). Then, in the post processing when I press results I have no results and when I press solve It says "no results selected for display or deformation, yet display or deformation switch was turned on in display template form".
Can somebody help me?
Thank you
Thank you
