Problem with booting
hi guys,
i've got this old stand a alone Toshiba with lcd.
the sys. comfiguration is: Pentium (r)A80502166 Processor, 32Mb of Sdramm, 4Gigs of harddrive. Os win98Se.
the problem is that, the booting process keeps restarting once it reaches the point of lunching Windows.
can anyone help me with a solution.
jeflickrservicesltd@gmail.com
RE: Problem with booting
TTFN
If it does, restart and try again in safe mode. Check if it boots up in safe mode. If it doesn't then it probably needs reinstalling.
If it does boot up in safe mode then there is something strange about the startup.
i personally suspect its a hardware problem,either the processor,motherboard or powerpack.
what do think?
Dan - Owner
http://www.Hi-TecDesigns.com
TTFN
Is it possible your cooling fan on processor heat sink has quit working? Or is there a lot of dust on mother board may need a good cleaning You could be over heating during boot, but win 98 always was a little fussy.
Chuck
