CTOD test on 5D Bends.
For sub sea pipeline usually CTOD test is carried out for both pipeline and 5D bend used in the pipeline.Can any body suggest the exact reason of doing CTOD( Crack Tip Opening Displacment)test. Because for piping under ASME B 31.3 piping this test is generally not suggested by any consultant.
RE: CTOD test on 5D Bends.
In your experience, does the CTOD testing you 'usually' come across also have stipulated acceptance criteria, or is it for information?  If the latter, it is to provide input into any engineering critical assessment (ECA) that may be performed later on.  If the former, it may be that the ECA has already been carried out.
Steve Jones
http://www.pdo.co.om/pdo/
A 5D bend is most likley made by induction bending.  Done poorly, properties will degrade.
OK - so what will a CTOD test tell us then?
Steve Jones
CTOD will tell us if the Induction Bend process has screwed up the toughness properties.  Charpy may also be used for this purpose.
Precisely - so why CTOD test?
Steve Jones
The advantage of CTOD is that it provides a K1 value at slow loading rates.  A K1 value can be used for determining allowable flaw sizes where as charpy energy can do so only poorly.  If one also looks for a minimal amount of CTOD stretch zone formation, say 0.15mm, then it is likley the piece has good toughness against both slow and rapid fracture.
The charpy test is a better (as well as faster and less expensive) test when the upper shelf material toughness is less than 100J.  (Some might put this in the 100J to 200J range) Below 100J, the charpy test is a high strain test and indicates toughness pretty well.  Particularly as one should also have pre-bend charpy data to compare to.
When pre-bend toughness is over 100J, charpy energy may be miss leading if too much of the hammer energy is being consumed by crack initation.  In that case, the test is not measuring toughness against high strain rate and may result in a miss-leading high toughness value.  Even so, a high charpy energy value is still pretty good and acceptable for many applications.  Charpy is still the most commonly used standard.
In my opinion, CTOD should be reserved for critical applications where technology is being stretched in one way or another.  Standard applications that have been done many times before should stick with charpy.
Thank you - we got there at last.  The only real value of performing CTOD testing is either to provide accept/reject information or to provide input into an ECA.  To provide accept/reject information, one must have an acceptance criterion or critera.  If there isn't one (or any), and an ECA is not going to be performed, then there is no point doing the CTOD test.
Steve Jones
