Linear bearings with low radial runout
I am looking for high precision linear bearings with low radial runout and clearance. Accuracy in the axial direction is less important for my application.
I am still inexperienced in this range but I could imagine that a linear bearing, eg. ball bearing, would work in the same way as a regular rotating bearing just with the balls rotating in the perpendicular direction, assuming a cylindric center rail. Therefore I hope that a similar radial Accuracy as in rotating bearings can be achieved.
According to specifications a radial runout or eccentricity of less than 3 microns (0.003 mm) is available in high precision ball bearings, but I wonder whether this is also possible in linear bearings, since I coudn't find any clearance specs referring to linear bearing systems.
I'll be gratefull for any help.
RE: Linear bearings with low radial runout
Did you tried Barden or Thomson?
Most linear ball bearing manufacturers (Thomsen, Barden, NB, IKO, INA)offer precision linear ball bearings that have adjustable clearences, designated by a ADJ suffix at the end of the part number.
I know IKO has some pretty extensive application information available online at their website.
Russell Giuliano
Thank you for your help, israelkk and Russell. Among the proposed Companies I found that IKO has the most comprehensive specifications on the accuracy and clearance of the linear motion products, together with Schneeberger, a swiss manufacturer, www.schneeberger.com. Both offer linear slides primarily rectangular not round, but that's even better. Clearance and parallelism for slides in the short distance range can be less than 2 micron in the so called "ultra precision"-version, this is perfect for my application and I'm very happy with that.
