High Temperature Glass
I am looking for a high temperature glass that can be processed at >650C. Is there such a glass?
RE: High Temperature Glass
TTFN
TTFN
Is this for a class?
You cannot willy-nilly select a substrate to deposit semiconductor material and expect reasonable performance. What material EXACTLY?
And what processing are you doing at only 650ÂșC? That's too low for anything except CVD.
TTFN
The question was not to deposit a CVD glass ..... it was to select a substrate with thermal stability properties that can withstand process temperatures >650C.
Thanks for your response, but if don't understand the question ........... that's OK.
So as you refuse to explain what you are trying to do, I can only suggest that you communicate with the suppliers you mentioned.
TTFN
http://www
Plesae read FAQ240-1032
WEB: <http://geocities.com/nbucska/>
ht
