Electric motors
Electric motors
Electric motors
Hi, anybody knows some web with solidwork drawings about asyncronous electric motors and pumps.
Thanks.
RE: Electric motors
Manufacturer hasn´t got models, and 3dcontent has not much models.
RE: Electric motors
I can get you a 3D model for every motor you order @ the company where I work winky smile
But then again, we only do special electric motors and centrifugal fans..... so that's probably not what you're looking for.
Mark
Sr. Design Engineer
SW 2006 Premium
RE: Electric motors
compressor ... does the manufacturer have 2D drawings? If so, you may have to create your own models ... and if you do a good job of them, the manufacturer may be willing to purchase them from you (or your company). Food for thought?
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Electric motors
We're in the business of designing and producing dedicated customer spec motors. That's everything thats not standard, like low-magnetic, high shock, high/low speed,  you name it. We will never be able to quote in a competitive way if a standard low-end e-motor can also do the trick.
Furthermore, every customer gets a dimensional drawing for approval. Those drawings used to be Autocad LT97, but we're now using Solidworks. If you would require a 3D model of the dimensional drawing, that can always be arranged but that's probably no different with our competitors.
Should you be interested, use google along with the search term "special electric motors" and you cannot miss us. However, I will not post the name of the company here since I consider that to be inappropriate.
Mark
Sr. Design Engineer
SW 2006 premium user
RE: Electric motors
foxbat1979 ... it is OK to display a link to your companys web site in your signature, but blatent advertising in your posts is definitely not wanted.
cheers
RE: Electric motors
@CorBlimeyLimey
Point taken, but advertising was exactly what I was trying NOT to do. That is not the reason why I am present on this forum.
Sr. Design Engineer
Solidworks/DBWorks user
www.combimac.com
