CONTROLS FOR WATER SUPPLY SYSTEM
I HAVE A PROJECT IS A WATER SUPPLY SYSTEM FOR A SCHOOL. I BELIEVE IT SUPPLIES IRRIGATION AND "OTHER?". IT CONSISTS OF A WELL PUMP THAT SUPPLIES 2 VERY BIG TANKS ABOUT 30 FEET IN DIAMETER. 3 PUMPS PUMP WATER OUT OF THE BIG TANKS INTO A SMALLER PRESURIZED TANK ( WITH AIR COMPRESSOR) THE SCHOOL WATER SYSTEM IS SUPPLIED FROM THE PRESSURIZED TANK. I HAVE PHOTO'S OF THE SYSTEM, BUT THE EXISTING CONTROLS ARE NOT CLEAR. THERE APPEARS TO BE A PRESSURE SWITCH AND A WARRICK CONTROL SYSTEM. TWO OF THE PUMPS ARE 15HP, ONE PUMP IS A 75 HP FIRE PUMP, ALL HAVE CHECK VALVES. THE CONTROL IS AN OLD RELAY SYSTEM. THE OWNER WANTS A NEW CONTROL SYSTEM WITH PLC. CAN ANYONE TELL ME HOW IT IS LIKELY THAT THIS SYSTEM WORKS, AND WHAT CONTROL ITEMS ARE NEEDED?
RE: CONTROLS FOR WATER SUPPLY SYSTEM
http://ww
