Toolbox Rebuild Issue
For some strange reason, when I insert bolts from the toolbox into an assembly, they have the rebuild icon attached, and will not rebuild even with a cntrl-Q?
It just started happening the other day.  Its not every config of the bolts however.  For example, in a current assembly I have 1/2-13 X 1-3/4 bolts that have the rebuild issue, and right below it in the assembly are 1/2-13 X 6-1/4 that are just fine.
Any ideas?
Mike Puckett
Group Leader
Los Angeles/Orange County SW User Group
Need Usergroup Info? www.swugn.org
RE: Toolbox Rebuild Issue
Which SP are you on? SP 4.0 caused this on our system; SW fixed the problem with 4.1
Craig Sink
Mechanical Engineer
Force Design, Inc.
We are on 4.0  It happened a few weeks after we went to 4.0, so I dont see an issue there.
Mike Puckett
Group Leader
That is known bug in SP4.0 you can either rollback to your previous SP or upgrade to SP4.1 were this issue is fixed at.
SPR# 315374 - Toolbox fasteners in assembly have constant rebuild icons on them when the the assembly is opened in SP4.0.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
