test pressure acc.to B31.4
hello all
 for a petroleum line,
Is the "test pressure" is 1.5 X "Design pressure" according to ASME 31.4
thanks in advance
RE: test pressure acc.to B31.4
thank you steve.
Does it mean that I can use a value of 1.5 ?
regards
As 1.25 x is a minimum, use of 1.5 x would satisfy the requirement but you may wish to look at the stresses you will be inducing in the pipeline.
Steve Jones
http://www.pdo.co.om/pdo/
As per ASME B31.4 the minimum Test Pressure is 1.25 x internal design pressure subject that in your pipeline stress induced shall not exceed 90% of SMYS.
So you should check your profile and if any of these conditions are not satisfied change your test sections.
Parviz Farhadi
Piping Lead Engineer
