Check valve downstream of a PSV
In a recent HAZOP, operators told me that they were under the impression that we could not install a check valve on a PSV discharge. Can anybody point me to the code that would reference this?
RE: Check valve downstream of a PSV
I do know I have never done it, or seen it done.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Besides, I can not think why you might want to place any restrictive device, or a device subject to mechanical failure downstream.
Paul Ostand
www.ostand.com
David
