using solidworks export in 3dxml:
Goodmorning!!!
I'm using solid works 2006 , then what is the way to export a part in 3dxml. I have seen in File > Save As but i have not found it .... do i have to install a plug-in???
thanks
RE: using solidworks export in 3dxml:
You need to be running at least SW2006 SP4.0. The files are pretty large. You can download a viewer from dassault, but I couldn't view every model with that viewer, seems either the viewer or the SW export function need work.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
