Configuration and layout sketch question
I have downloaded an assembly (native solidworks) with a layout sketch that drives the stroke. I added a configuration (by changing the layout sketch depending on current config) for the stroke and it behaves as it should. However when I insert this assy in the upper level assy and have two configs one default and one stroked you seem to only get the config last saved. Even doing a rebuild or resolve does not change the assy as it should. Looks like the top down sketch is not rebuilding. Any ideas?
Thanks in advance.
Thanks in advance.
RE: Configuration and layout sketch question
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
It probably has something to do with the way you can only edit a dimension of the active configuration of a part. Consider changing the mating scheme of the downloaded subassembly.
