Flat pattern Sketch
Flat pattern Sketch
When I flatten my part and sketch some slots on the flattened part then extrude cut them they are no longer there when I go back to the formed view. What am I doing wrong.
SolidDesign
SolidDesign
RE: Flat pattern Sketch
The Flatten is actually a feature you are suppressing and unsupressing so if you suppress it (unflatten) anything after it in the tree will be suppressed as well.
Are you creating a Config of our flattened parts? Chances are the new features are in this Config, you will have to move them or change your Config properties to show them in the formed state.
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
