FORMULA FOR FRICTION CONE
COULD SOMEONE TELL ME HOW TO CALCULATE HOW MUCH FORCE CAN A FRICTION CONE USING LINNING CAN TRANSMIT.
I HAVE A GEAR WITH A CLUTCH CONE FOR ENGAGING A DRUM AND I NEED TO KNOW IF THE TORQUE NEEDED FOR LIFTING A LOAD CAN BE TRANSMITTED THROUGH THIS FRICTION CONE.
THANKS.............
THANKS.............
RE: FORMULA FOR FRICTION CONE
T = Fn * Rmean * Mu
An appropriate safety factor needs to be applied. If the clutch will be slipping in normal operation the heat dissipation needs to be considered, and the allowable loading of the friction material must be considered.
Jeff
They elementry textbooks on static and dynamics?
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
AND I´LL CHECK THOSE TEXT BOOKS IF I CAN FIND THEM.
