DIMENSIONING
DIMENSIONING
I PLACE A DIMENSION SOLID EDGE PUTS THE ARROW'S INSIDE, I WOULD LIKE TO CHANGE THAT TO ARROW'S ON THE OUTSIDE CAN I DO THAT???
RE: DIMENSIONING
I may not have the answer but just some ideas.
I am interested in this forum because I may be moving on to employment with a company that used SE. I've got an Eval CD on its way. Currently using SW
Adam
Solidworks 2005 SP01.1
Windows 2000
RE: DIMENSIONING
at least in V18/SP3:
select one of the arrows and drag it to the outside. It's a little
bit cumbersome because sometimes SE won't recognise this and will
move the dimension up and down instead. If thsi happens you
have to click into empty space to unselect and reselect
dy
RE: DIMENSIONING
RE: DIMENSIONING
I am running solid edge v18. Trying to place a part on a Draft file with other parts (that will show up on the bill of material), but I do not want it to show up in the list of material. How can I set this up????
