Drawing section cut
Drawing section cut
Hi all,
I have an extruded component which twists in 3 planes.
A solid swept on a curve on a compound surface (door glass).
How do I make a true section of this part at a specific point in a 2D drawing.? I don't have a view which in normal to the section plane I want to cut on.
In Catia 4 I could just pick a plane in 3D space and create an independant view. I don't seem to be able to do that in v5.???????
HM
HM
RE: Drawing section cut
Derek
I need a true section normal to the extrusion,
which at no point is normal to any of the views.!
Now you have a normal plane in right position
Now you can either use inersection in GSD or create a sketch and use "intersect 3D element" (remember to pick the body in the tree before activating the feature so you don't get entitys of the solid instead of the whole solid).
HM
