SAE J405 30303= 303 STAINLESS ???
3
I have a part for quoting with material spec "SAE J405 30303".  Is this a machining grade 303 stainless steel?
RE: SAE J405 30303= 303 STAINLESS ???
There is no designation 30303 in SAE J405.
Cory
Yes, SAE J405 JAN89 shows a designation 30303 for 303 free machining stainless.
I suppose I should clarify my answer.  I used the most recent version of SAE J405, dated 1998-06.  If this is a part for a new quotation, you should contact your customer and inform them that this alloy has not been listed in SAE J405 for nearly 8 years and that a different alloy or specification should be used.
Cory
