Heavy metals remediation?
Folks,
I have a site with heavy metals contamination, primarily Lead (600ppm), Zinc (1000ppm) & Tin (8000ppm).
The site was a "brownfield" site approximately 30 years ago, the contamination is not related to current activities on site. The levels above are from a soil survey conducted approximately 10 years ago, we are intending to re-survey to monitor for changes.
What sort of remedial/treatment processes would be available for soils contaminated with these sort of levels? We are currently intending to redevelop part of the site, and it may prove more sensible to initiate remedial action now, rather than later.
Michael
Michael
RE: Heavy metals remediation?
Wait for the results from the new survey. From this you should be able to determine if the site is completely contaminated or whether you can delineate the site into 'hotspots'. The end use of the site is very important. If it has a sensitive end use (say school, or housing) then the guideline values may vary from say an industrial complex.
Any areas that will be covered with hardstanding / concrete / paving there will be no pathway for the contamination to pose a threat to human health. Areas of soft landscaping or allotments should be identified, probably excavated and infilled with clean cover from a certified source.
Sorry, I'm waffling a bit. It isn't that complicated really but a good geo-environmental engineering firm should be able to take care of this for you.
Soil stabilization is an alternative if you need to prevent leachate from contaminating the groundwater.
A good stating point for your research is this EPA website: http://www.epareachit.org/.
If leachability is a concern use the SPLP method instead of the TCLP method. I find that many consultants mistakingly use TCLP to test leachability in in-situ soils.
In the interim, leachate is more of a concern (sandy-clay soil) into the water table below. I'm having the previous survey repeated - if the metals content is approximately the same, then I presume that the metals are fairly stable (for the time being, i.e. not leaching to any appreciable degree).
If I see a reduction in the metals content, am I right in assuming that leachate would be the main reason for this? Or are there other vectors that could reduce the metals content? There is no organic cover on the site in question (industrial site)
Thanks in advance,
M.
p.s. - there is a small BTEX plume on the site as well (old boiler house - USTs) but I have plenty of options in relation to dealing with that, not sure if that might affect options on the above.
However, a "true reduction" in concentrations is important to define (as opposed to an apparent reduction). You'd have to consider the accuracy of the analytical method (typically +/- 25%). Also, is the lab using the same method now that they used 10 years ago?
soiledup
I'll be using the same firem that conducted the previous survey, basically repeating the survey (with a few extra points for the BTEX plume), so it should be as close as I can get to the original.
soiledup - Ordinarily, that would be fine, but remediation would be the option more than likely forced on us at decommissioning, regardless of end use (or potential end use). As I said, welcome to the EU!
Thanks folks!
M.
This basically comes down to using a good geo-environmental site investigation company who should be able to mitigate any planning conditions imposed.
Remediation would be the company's preferred route anyway, it's just a matter of cost - hence my query on current technologies for HM removal.
Thanks!
M.
