What is a Retort
What is a Retort
What is a Retort
As a piece of process equipment, what should I understand by Retort?
From the process as well as mechanical design standpoint, how does a Retort differ from other kinds of vessels? I have not come across this term in mechanical design references so far, possibly by oversight. But I feel it is more of a chemical engineer's usage.
Any references for further reading will also be greatly appreciated.
Thanks.
RE: What is a Retort
The common description -among others- would be: a spherical vessel with a long neck, like a number 6 rotated clockwise by 90 degrees. See
A retort is a rather primitive laboratory glassware used for distillation or dry distillation of substances. In the latter case in many cases where the absence of air is required. It consists of a spherical vessel with a long downward-pointing neck. The liquid to be distilled is placed in the vessel and heated. The neck acts as a condenser, allowing the evaporated vapors to condense and flow along the neck to a collection vessel placed underneath. In industrial applications it is an airtight vessel in which substances are heated for a chemical reaction producing gaseous products to be collected in a collection vessel or for further precessing.
you can find more details on the following link:
http://en.wikipedia.org/wiki/Retort
Thanks a lot 25362, GUMBASE for the quick and very useful info.
So, for the purpose of the chemical industry, I take it that a  Retort is essentially a spherical pressure vessel (with outlet at the top, of course).
If it is required to be designed in SS or a special alloy, then I suppose the relevant ASME Sections would be applicable.
I await your further comments. Also, I am still on the lookout for any references.
In the food industry, a retort is a horizontal or vertical pressure vessel used for processing foods - basically a pressure cooker.  All shapes and sizes included from batch to continuous processing, but I never have worked with one.
Thank you, twr. That was one of the most relevant and to-the-point responses I got.
Afterall, it was apparently from the food-processing industry that the query was received in the first place.
I don't see much about these units on the web - the core text for low acid food processing has descriptions on all types of retorts, which might help.
"Canned Foods: Principles of thermal process control, acidification and container closure evaluation."
Garvin, A. and Weddig, L. 1995. The Food Processing Institute. 6th Ed. Washington, DC
Thank you, twr. Will lookup the reference asap.
I should have been the first to give u the star - better I do it now.
