Downward Compatibility Function
All,
I am attempting to use this utility and the only thing that is converted is data in PartBody. Is there a way to get the entire part to be converted including GeoSets i.e. surfaces, curves, etc.
Ross Parpart
Product Design Engineer
UGS NX3/CATIA V5R15
www.decoma.com
RE: Downward Compatibility Function
Enable Hybrid Design, and then reorder the GeomSet to be under the PartBody. Now run the DownwardCompatibility utility.
Ross - I just tried moving the GeomSet as I previously suggested, but it only had the copied solid with no surface or wireframe. (I'm currently using R12)
