Absorption chiller against common chiller + ice rink
Hi Fellows!
Suppose a retroffing operation where a common DX chiller is selected to serve in an existingg installation, giving its sensive power at 7 - 12 ºC in the afternoon and during the night (low electrical rates period), working to charge a ice-rink at -6ºC ~ -5ºC for coping the next morning period (high electrical rates period) against an equivalent absorption chiller solution.
Some guidance is required, any hints, comments. Thanks.
RE: Absorption chiller against common chiller + ice rink
http://cipco.apogee.net/ces/library/tcac.asp
so far, my experience is with 50C min. temperature absorption chillers. LiBr+Water is definitely not an option for you. Check for Water+Ammonia systems.
The main prerequisite for absorption chillers is waste heat. If you have to generate heat to run an absorption chiller, strike it out, unless your power cost is too high.
On the operational front, my suggestion is to, consider a generous quantity of Aspirin, as a standard item, in your inventory list.
Good luck,
Do you dose your absorption chillers with Aspirin?
(hairpull)
We are back to hieroglyphs, ironically.
http://
Ice Kube uses heat pumps for ice production, either georthermal or via a cooling tower loop
http://www.cimcorefrigeration.com
CIMCO standard ice rink plant with heat recovery.
Thank you so far for your replies!
I must say we are working here on office-building and there is not any spare/waste heat. In the absorption chiller option we should analyse a direct gas-fired heat source chiller unit.
Welch
