KVA (power factor)
KVA (power factor)
HI all, I want to find out the KVA of my house. I have a voltage supply of 230 volts and it is protected by a 63amp switched fuse. thaks guys.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: KVA (power factor)
The KVA of a circuit is the volts time the amps divided by 1000. Very simple.
This is not the power factor however. The power factor is the KW/KVA.
Best regards,
Mark Empson
http://www.lmphotonics.com
Actual KVA, unknown, insufficient data.
Power factor, unknown, insufficient data.
yours
