element deleetion - debonding
Hi All, I am using element deletion method to find out the failure of the materials. I use STATUS option from the DISPLAY GROUP to visualize the element deletion but I could not see any deletion.
I have five parts in a model and they are in contact with TIE constrain.
So, in this regard, what should I do to visualize the failed elements.
HOpe to have your suggestion in this regard.
RE: element deleetion - debonding
If you dont see any deletion it is that your STATUS do not contain any deleted element. Did you define your failure criteria?
Yes, I have defined the failure criterion but still not able to see the deleted elements.
STATUS shows BLUE colour elements without deletion......
