Motorcycle/bicycle fork lubrication... how does it work?
I postes this also in the Automotive forum, but I think this is a better place to get an answer.
The question is why do bicycle and/or motorcycle fork manufacturers use very little oil (less than 50cc for a bicycle fork) on the non-damper side leg, for bushing lubrication?
I gather that the lower bushing gets splashed with oil with each stroke.
What about the upper one?
Some manufacturers use hydrodinamic lubrication and make grooves on the bshings, but most of them don't.
Anyone has a deeper insight on this topic?
Thanks!
RE: Motorcycle/bicycle fork lubrication... how does it work?
Because they use high performance self lubrication bushings/bearings
http://www.ggbearings.com/literature.asp
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
