high strain material
I'm looking for a materail which its strain value is highest possible. I would like to find a material which able to absorber all the energy when an objet is falling down. The masse of the objet is about 100 kg and it falls from 0.6 m. Is it possible to calculate want is the thickness required and want kind of the material? Also, I would like the material less thick as possible.
Mica
Mica
RE: high strain material
http://www.sorbothane.com/
Strength of the material and energy absorbtion or a structure do not necessarilly have a direct relationship.
Mica
Does the protective structure need to survive the impact with no damage, or can it deform permenantly to do its job?
Mica
How do you expect us to answer that question. We don't know what you are trying to do.
It seems like you don't know what you are trying to do either.
Mica
