DWGgateway problem
DWGgateway problem
DWGgateway problem
1. I open ACAD 2002, open dwg file and use DWGgateway. Works OK.
2. When I open dwg file from Explore, DWGgateway does not work. Message is "Unknown command". Toolbar is on the screen.
How can I fix it?
RE: DWGgateway problem
Why do you open ACAD 2002 and DWGgateway? They are two different programs. When you try to open from Explore, you are getting a conflict between the two.
Chris
Systems Analyst, I.S.
SolidWorks Pro 06/PDMWorks 06
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Cris,
I open only ACAD and I see DWGgateway toolbar on the screen.
From Explorer I double click file and get DWGgateway on the screen. I don't open two programs. Only ACAD.
Now I use SWorks to create PDF files.
