API 650 Conical Bottom Tank
I need some info regarding design of API 650 tank with cone bottom, what code should be use along with 650? what type of bottom support will be required (Skirt or Legs)? and how much the slop will be? This is for SAGD water treatment application
RE: API 650 Conical Bottom Tank
API-650 doesn't cover cone bottom tanks.  The rules in API-620 do cover that configuration.  API-620 is intended for low-pressure tanks, but the rules will work on atmospheric tanks as well.  You don't necessarily have to do all the API-620 inspections to use API-620 for the design.
Using API-620, it does take some understanding of how the methods work, and it is not just a cookbook approach.  In particular, you have to understand how the free-body diagrams need to be set up for a particular configuration, and may need to add terms that are not present in the published equations.  A skirt-supported tank designed by API-620 is fairly straightforward.
API-620 does not cover leg design, and I've not seen anything that covers the subject well.  AWWA D100 includes elevated tanks of any configuration, but doesn't give you any helpful design information- and does give some misleading design information.  Gaylord & Gaylord have a "Structural Engineering Handbook" that shows some hopper design with legs, but the method shown fails to address some major issues (torsion, for example).  I've not really seen anything any better, either.
Another configuration you might want to investigate is a scalloped-bottom configuration.  However, the detailed design of those becomes very awkward, and approximate designs also tend to leave major items unaddressed.
JStephen
Wow.  It's been a long long time since I was reminded about the scalloped bottom tanks.  I designed a bunch of them many years ago for an alumina refinery in Western Australia.  Thanks for the reminder of fun times in Oz.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
JStephen, Thanks for the reply
