Abrasive Sand Blasting
I was reviewing a set of bridge plans and there was a note that stated all existing steel would be "abrasive blasted to a SA-1." Any ideas on what SA-1 is referring to? Is this referring to a specification on abrasive blasting or a surface finish.
RE: Abrasive Sand Blasting
h
This link gives a brief explanation of the differing grades of finish available.
ht
Brush Off - Loose mill scale, loose rust and foreign particles are removed.
Simular to SSPC SP 7 or NACE No.4
www.wjleigh.co.uk/images/SurfacePrepSteel.pdf
www
